I've had an ongoing problem with my Safari appearing not to charge - solved the problem now but thought I'd share the story as it may help others.
When starting the glow plug light would come on for a split second than go out, I'd kick the fuse panel it sometimes the light would appear for a split 2nd.
When truck started - within 5 minutes the volt meter would go down below 24 volts
Alternator checked by sparky and in working order
Batteries checked and they were fine to
Checked alternator when truck was running and it appeared overly hot (working hard charging)
99.9% sure I've found the problem - glow plugs staying on or similar draining all stored and generating power whist truck running
Checked the 2 wires going into the resistor poking into the air intake manafold and they seemed warmer than expected
Disconnected the plug to the resistor and started the truck - all charging fine and no longer draining the battery.
Stopped trucked and left for a while - tried to start and glow plug light only on for split second as usual
Swapped the glow plug control box below the fuse panel for a known working box
Tried to start truck - glow plugs now working as they should - truck charging etc as it should
The resistor is used in extra cold conditions to control glow plugs and is not necessary to run the truck
So......if you have a truck loosing power - try disconnecting the plug to the resistor - it may just be the problem !
Non charging electrical problem solved !
- catalystracing
Re: Non charging electrical problem solved !
Thanks for taking time to post, it is all helpful stuff.
the resistor will be for the after glow. they usually run the after glow until engine heats up.
it may not have been the control box. can also be the temp sensor (it will keep going if it thinks the engine is cold)
and can be the relay. the relay may have welded the contacts together .
so just keep an eye on it for a bit and make sure the problem doesn't come back.
