can you legally run 35' creepy crawlers on the street ?
adventures_more
Post by adventures_more »
looking at getting bigger tyres later on and quite like the creepy cralwer , i hear they are Bias ply but feel like radials ,can you legally run 35' creepy crawlers on the street ? what would they wear like ? they'd be more used for rock's & stones , sand, snow .
DaveM
Post by DaveM »
You would need to get a LVC for the truck to run 35's, once you have that, you can run them legally.
Can't see them being good in sand, but others will give more detail as to what they are suited for.
DieselBoy
Post by DieselBoy »
I run a set on my Safari, bloody good in the mud, rocks, rivers, wet grass you name it.
Really quiet on the road, and they are wearing extrodinarily well for an aggressive tyre.
There isn't any mention of tyre size in the WOF manual, only that the tread must be covered by the guards or flares. Side walls can protrude from the gaurds/flares. So there for, no cert required.
DaveM
Post by DaveM »
I'm going through the process with the mods on my truck with the local LVC guy, and he has pointed out rules for needing a cert on a tyre increase of 5% or more in circumference, and any changes in body mounting, which would include body lifts :?
Will just pay for the cert I think, knowing how insurance companies always try to find a way out in the event of a claim.
wjw
Post by wjw »
It MUST be certed if the rolling diameter is 5% larger than the OE Spec.
Specs:
http://www.ltsa.govt.nz/publications/vi ... s-v2-3.pdf
Vehicle Inspection Requirements manual:
http://www.ltsa.govt.nz/publications/vi ... index.html
Has an FAQ on here thats useful
http://www.lvvta.org.nz/
you can fit any diameter wheel as long as the rolling circumference (the distance one turn of the wheel travels on the road) does not increase more than 5% over the original equipment without the need for an LVV cert. The main reason for this is that a substantially increased rolling circumference will make the speedo under-read (i.e. the speedo will read, say, 90kph when you are doing 110 kph).
Unfortunately what needs certifying isn't always in the WOF book.
The other thing to think about with ANY mods is that your insurance company may not cover you without a Cert.
Who knew Prados could fly?
Monty
Post by Monty »
my mate just bought a 88 lwb saffy got it 3pm sat we drove it out of his work shop about 7pm with a 60mm lift new shocks and 35 creepy crawleys it looks mean but i don't think i would buy them just just don't look right but he said he's just going to take them off for warrants but in saying that he also is taking his carpet out to but he got so much further than me with my warn 33 muds and we were playing in shingle yesterday so ..........
I WISH I WAS A WINCH MASTER BUT I NEED A WINCH TO DO THAT
1991 safari with none of the boxes ticked im a fool!! SOLD
1996 nj paj 2.8td but with the diff lock box ticked :)
1978 DATSUN 180B sr20 POWERED
xj
Post by xj »
Been through this, if memory serves correctly the factory tyre on the jeep was 235/70/15, (some came out with 225) to go up to 31 x 10.5 x 15 meant an increase of 7-odd percent... which is obviously outside of the 5% threashold of the lvva requirements. . . . . . seems that particular requirement is a tad tight.
The only thing i can recall regarding height specs was that a car HAD to have 100mm body clearance from the ground and its lowest point (obviously aimed at lads in their jappas).
Regarding suspension modifications, again, only as far as my memory reaches, there was no restriction on height, provided you used the factory mounting points and they werent modified in any way.
I couldnt recall anything about body lift, but seeing as how i cant body lift, i probably didnt worry about that part.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
mudhaw
Post by mudhaw »
As far as Im awere up to 2" bodie lift doesnt have to be certed but bigger tyres do as they increase the leaverage on the brakes and there for dont stop as well. But in saying that cirt plates only state the rim size.
My addvice, if you need any thing to be certified get every thing listed, bodie lift, tyres, bull bars, side bars etc you never know what the rules will be next week and cirts are not the cheepest. And the copps dont know the laws that well
DaveM
Post by DaveM »
To be honest, when it comes to mods and what needs certing, I would either get the info off the official site, or ask your local certer, as the wrong info could potentially cause a LOT of strife.
I've had a mates claim refused after he wrote his truck off while running uncerted 33's. He did the normal tyre swap for wof's but got caught out when he had an accident.
Company then refused to insure him again, and he had a real battle to get covered by anyone else.
wjw
Post by wjw »
And these are the OFFICIAL sites:
wjw wrote:Vehicle Inspection Requirements manual:
This is also useful:
Return to “Tyres”
