Hy old rear brake caliper on terrano d21 is needing replacement tried reseal kit but piston is damaged and wont seal. Had a look around wrecking yards but none about, does anyone know of another car that uses same rear caliper? tried search function no joy
or even another car that uses same piston cheers
terrano rear caliper swap question
Re: terrano rear caliper swap question
You can buy the pistons on their own. I did this when rebuilding the front calipers earlier this year as they were quite badly pitted.
BNT stock them, although they aren't cheap. You can try TradeMe too, I know they have toyota pistons. Some other Nissan vehicles probably use the same calipers/pistons, so it's worth having a measure up of the diameter and depth etc to see if they can be cross-referenced.
Toyhatsu Bitsalux
cheers will have a search
- catalystracing
http://www.huttcityautoparts.co.nz/
Ask for Craig, tell him Paul yellow hilux told you to call him.
They are often cheaper then BNT.
Just have rego details ready so they can search properly for you.
Worth a shot.
Cheers.
Worth a shot.
Cheers.
