Hi all,
Bit of a curly one. Fired up my LN106 with 3L for the first time in 5 years and its running like the throttle is stuck open.
Fresh diesel and diesel filter, correct amount of oil. Air filter attached. You can manipulate the throttle arm on the injector pump and it does nothing, just revvs straight out like its stuck on full throttle.
Anyone experienced this? I can only think of it being an issue with the injector pump which looks like it runs on black magic.
3L throttle stuck open?
Re: 3L throttle stuck open?
id say the needle valve is stuck open
any luck with it?Danger wrote:Hi all,
possibly regulator stuck especially if fuel drained out of pump while it was sitting.
i assume its turning off so its not running on engine oil.
