D22 260mm, 6 bolt clutch??
Hi guys, bit of a question for the parts gurus out there. I'm looking at putting the FS5R30A gearbox in my (BD30 powered) Terrano. From what I've read I can get one from a D22 Navara, however looking through the Exedy website shows the QD32 Navara uses a 260mm clutch, instead of the 250 or 240mm that are commonly talked about. Can someone confirm this, and if I would be able to use the flywheel, clutch, gearbox, and driveshafts from the QD32 D22 in my Terrano?
