Does anybody have a spare pitman arm? The taper for the ball joint is flogged out so wanting a unit I can swap in quickly.
Has the larger spline. All units I have seen at wreckers are smaller spline. Trying to avoid going through Nissan to keep cost down. Appreciate any help. Cheers.
Wd21 pitman arm
Re: Wd21 pitman arm
Stumbled across this just before reading your post, weird...
https://trademe.nz/motors/car-parts-acc ... 2151969967
Re: Wd21 pitman arm
Have made contact! Now the task of removing my pitman arm. Cheers.
