Hi Guys doing a G16A swap into my sj413 and wondering how you have waterproofed the ecu and where have you mounted them?
also got a 8274 going in the rear feeding the rope forward how have you protected it from heat from the exhaust
SJ413 with a G16A bush truck
Re: SJ413 with a G16A bush truck
I did a similar swap and made a bracket to mount the ecu high up under the dash on the passenger side above where the loom comes through the firewall. I didn't waterproof mine. Plenty of guys have used plastic containers for that though.
