Jimny with engine knock.
For all Suzuki related topics
clubbing80s
Post by clubbing80s »
Hi,
My Jimny had a tick that developed to an engine knock.
A short video of the engine https://youtu.be/DCPoHYkAo6I .
What is likely to be the issue? so far I have been advised it's a rod knock.
What would it cost to repair ?
Rather than send to the wreckers Id rather it goes to someone as a rebuild project, hopefully for a better offer than the wreckers.
Any thoughts /suggestions ?
Thanks
G
turoa
Pyro Junior
Re: Jimny with engine knock.
Post by turoa »
Hi,
Bit hard to tell from the video but sounds like it it coming from the top rather than the bottom. Maybe timing chain tensioner gone? Either way I wouldn't send it to the wrecker. Worth a reasonable amount of money still and those M series engines are dirt cheap (as they come in swifts also). Quick look on trademe and an m13a out of a swift is only $500 from a wrecker. Would need to swap a bunch of bits from your jimny motor to swift motor but not hard, and so worst case scenario is not that bad.
clubbing80s
Thanks for that. I'll have a look at replacing the engine.
Return to “Suzuki”
