Girlfriend went out for most of the day so i managed some garage time, result is the hilux now has an engine in it again
And a gearbox
Looks like I'll have to modify the sump for some diff clearance
DieselBoy wrote:
Oh, and i managed to put 4 holes in the radiator while tryin to take a short-cut
mudzilla wrote:Good work Lolyf,,Hope you know good auto sparky to sort out that birds nest in the corner of the engine bay...
fweddy wrote:
I have noticed it getting pretty hot under the bonnet after even short runs. I'll do a radiator flush but what other areas are worth checking for over heating? (no bubbling in radiator so hoping the head is ok)
Mattman wrote:You should pressure test the whole system first to make sure it's holding pressure. Replacing the cap and thermostat is pretty easy and cost effective.
When it's hot you should hear the viscous fan, it should be moving a lot of air especially if the motor is pulling 1500rpm or so.
If it hasn't had one yet a water pump and viscous fan is probably needed although this might not be the only problem. At high km's the fan stops locking up and the water pump impellor wears down and reduces it's efficiency.
Matt.
fweddy wrote:
I then took off the 'thermostat cover' to find its not, then found the thermostat on the inlet side of the engine (what's with that?)
