fj40 body lift
- niblik
- Sausage Shack
mids are from under the body, inside the chassis rails, there is a little 'pocket' which the mounts are in.. the bolt tops are captive so just undo the nuts from below... its just that easy..
the fronts are from in the drivers foot well and directly under, and passengers same dealio..
there should be 6 body mounts on tub if i'm correct? 2 up front, 2 mid and the rear bar pair..
if the ones ya thinkin of are able to be seen in the rear wheel well, they just sit on the chassis and are not connected to chassis at all, they just sit there supportin the tub..
are these the ones you mean?
if not..... sorry....
