Whenever I end up following sheep, they always run in front of me and won't pull off the road.
I have now been told that the reason is that sheep think the car is a predator chasing them. When they are being chased, if they cut to the side, the predator can "cut the corner" and catch them so they keep going in a straight line until they outdistance what is chasing them.
The answer is to chase for a few seconds then drop back. The sheep thinks it is winning the race an now is safe to dodge to the side.
IT WORKS!
Getting Those Sheep Out of the Way
- rollypolly
- Driver/Navigator
A sudden change in direction will do it as well. Assuming you are on a road just turn to the right so that you are heading across into the other lane. They will usually then turn the opposite way and do a U turn to get away from you (you've gone wide and they cut back the other way to extend the gap between them and you).
Obviously it all depends on the size of the mob and how tightly packed they are.
The other way is to just speed up and get right up their arse and they'll turn away to avoid getting run over!
But that's a bit risky because quite often they don't turn in time or can't turn because of the others either side of them and you end up running them over. This is OK on a quad bike but car or 4wd will usually do a bit more damage to them!
- deer_hunter
- Driver/Navigator
Problem with many of these solutions if the cocky that you are likely to make grumpy with your antics.
I think tho that the original idea of moving forward into the mob then dropping back does have something to it when I think of past experiences.
I should take the truck out into the paddock and give the sheep a try.
But then sheep are crazy things at the best of times... We have had some (as well as a calf) that I'm convinced had mental issues (how many calves have you seen run full steam into a cyclone gate and live with the mesh pattern engraved into its nose!).
I would just like to point out that my second suggestion was just a piss take and that you should not try it! It was very irresponsible of me to even say it on a public forum where people who do not have experience with stock may read it and think that it is a good way to get them to move off the road.
As fweddy pointed out, you are likely to end up with an irate farmer (with just cause) to come flying up alongside you with spit coming out the corner of his mouth as he's hurling abuse at you and trying to run you off the road in order to share his views of that method with you.
But seriously, if you encounter one or a few sheep on a road/track that has banks or scrub on the sides they will just run down in front of you until they find a suitable place to pull off the road. The faster you go the fewer of those opportunities appear because they are thinking about getting away from you rather than looking for places to pull off the road. As David said, if you slow down or stop they will slow down and start looking for those opportunities and get out of the way quicker. Sheep don't like to run for the hell of it, they will almost always try their best to double back and/or stop and get out of your way.
If you encounter a mob of sheep being mustered down the road in the same direction as you then my first option above is probably going to be a better bet because if you slow down/stop then they will just carry on as a mob in front of you as if they are being mustered by the farmer. If you "go wide" in either direction (to put the most sheep on one side of you) then they will either stop or turn back and allow you to sneak around the outside. Again, this will all depend on how wide the road and verge is , how many sheep are in the mob, and how tightly packed they are.
If you encounter a mob of sheep coming towards you then you are best just to stop and wait for them to go around you. Otherwise you can edge forward at a slow crawl and they will just open up a hole around you as they flow past.
One thing you will notice when mustering (herding if you will) sheep is that there are:
- leaders, those that are always out the front trotting along looking for ways to go that the farmer would prefer that they didn't go
- followers, those that just plod along in the mob, usually trying to stay somewhere in the middle of the mob out of harms way
- slackers, the ones that always end up at the back and you have to push them along the whole time
- sickies, the ones that always fall behind panting/limping/collapsing and you sometimes have to carry on the back of the ute/bike because you can't wait for them any more
- cunning buggers, those that duck off into the scrub at any given opportunity and end up getting missed for shearing every year and end up like Shrek the ram (became world famous recently... somehow
So each situation will be different depending on the type and personality of the sheep.
Bloody hell... anyone would think I'm a sheep psychologist or something....
Sorry about the rambling!
- Moriarty
Re: Getting Those Sheep Out of the Way
David wrote:Whenever I end up CLIP then drop back. The sheep thinks it is winning the race an now is safe to dodge to the side.
IT WORKS!
You really don't mean that do you?
I mean about sheep thinking.......
