Im wrecking a rangerover
turoa
Pyro Junior
Post by turoa »
After having blown the transfercase on the Rangie, I am regretfully pulling it apart to wreck for spares. It requires a bit of work to get road legal again, and it has a lot of dents. I no longer have 4 matching tyres as one of them blew apart on the haywards road. There is an LPG kit up for grabs, but mike had his eye on it for awhile, and has asked me to sell it to him first quite awhile ago. Otherwise that is up for grabs (MrO :wink: ).
The money I get off this will go toward getting my LandRover going and on the road, so buy away.
I will be very sad to see it go, but hopefully Ill see you guys out on the trail fourwheeling sometime soon.
Turoa
doddzee
Is Doddgee
Post by doddzee »
You have been wrecking that thing since the day you got it :D
MWB V8 Safari Ute
turoa
Pyro Junior
Post by turoa »
doddzee wrote:You have been wrecking that thing since the day you got it :D
What, I occasionally made it better :lol:
I beleive my snorkel and waterproofing on the dizzy must have worked cause I had water bonnet depth and it kept going :twisted:
doddzee
Is Doddgee
Post by doddzee »
What are you doing with the motor? Keeping it for a rainy day to transplant into the landy?? :wink:
MWB V8 Safari Ute
turoa
Pyro Junior
Post by turoa »
doddzee wrote:What are you doing with the motor? Keeping it for a rainy day to transplant into the landy?? :wink:
The motors *nearly* stuffed. My dad thought that the engine was going to go before before the transfercase.
If you need any confirmation on how stuffed the engine is, ask anyone who was stupid enough to follow me Image
Yep..... I can verify that :fire:
Will the diffs fit Mr O's beast...or useful as spares?
turoa
Pyro Junior
Post by turoa »
Jerry wrote:Will the diffs fit Mr O's beast...or useful as spares?
Yes, they should fit
mercutio
Post by mercutio »
i think the disco ones are stronger aren they correct me if i am wrong
jdeburgh
Post by jdeburgh »
mercutio wrote: i think the disco ones are stronger aren they correct me if i am wrong
I'm pretty sure the early disco's were the exact same, but the later ones had more splines and therefore stronger.
However, still does not get away from the big wheels & tyres = more stress on the running gear, regardless of what vehicle it is.
John
Cloggy_NZ
Texas Chainsaw
Post by Cloggy_NZ »
Don't think so, not the early 10 spline ones fitted to Disco's up to about '94. I can vouch for that, only broken 4 so far. :(
The later 24 spline had stronger axles but the carriers themselves are not much of an improvement. Certainly not worth the money some people try to sell them for.
jdeburgh
Post by jdeburgh »
Yep, stonger axles not the rest!!
Still....regardless...stick by my big tyres etc theory!!
John
