Has recently had the following work:
- New cambelt
- New top tank for the radiator
- New front brake pads
- New right/rear axle seal as previous one was the wrong size and causing it to leak
Few Details on the Suzuki:
-1992 Escudo (Helly Hansen Special Edition)
-215,600km
-3 Door
-Dark Blue
-1.6L 16V (G16B)
-Auto
-Straight Body
-New WOF/REGO 'till May '07
-Hi-Low Range 4wd/2wd
-Air Con (Perfect for converting to On-Board Air), Power Steering, Central Locking, Power Windows etc...
-JVC 50x4w CD Head Unit
Additions:
*30x9.5x15 Kumho Powerguard Mud Tyres 8ml tread on WOF sheet
*'Blue Spoke' ROH Wheels (Painted Mags, not whitespokes)
*Yellow Rear 10,000lb Rated Tow Hook (Fitted using Rated Bolts, and 6mm RHS)
*Yellow Front 10,000lb Rated Tow Hook (Fitted using Rated Bolts, steel plate sandwiched inside/ stainless outside of chassis)
*Blue Custom Front Bar (just a Single Curved Bar) to gain maximum approach angle.
*Custom front thick aluminium checker plate bash plate (not a skid plate as such) only covers bottom of radiator/engine bay/front crossmember etc.
*Approx 40mm lift - Yellow Springs, Red Rear Shocks
*Blue Sections of interior dash.
*Seat Covers
Club requirements included:
- Spade
- Basic 1st Aid Kit
- Snatch Strap
- Fire Extinguisher (2x 1kg)
Body is good with no visable rust - just some light surface scratches from bush bashing escapade which should buff out, roof has some clear coat oxidisation but this is no show pony so hasn't bothered me.
Looking around $3,750
I'm located in Mt Wellington, Auckland
Matt
021 1300612
09 570 7061
Pic's:
(Can get more pic's of inside and engine ect..)
