I have a series 1 landie, see below, and wish to attach a winch. I dont want to spend much (mainly as i aint got much TO spend - benefits of being a student studying!! haha) and would prefer a pto one (i think??).
Landie has a holden 186 in it.
Any suggestions, advice or ideas would be greatly appreciated.
to fit a PTO your gearbox (or is it your transfer?) has to have the place to put a shaft in it to run a PTO winch and you would need to find a second hand unit on the likes of trademe. An electric winch would be easier if you dont have this option on you driveline for a PTO go for a electric winch. But beware the cheaper ones aren't that great (you get what you pay for) but in saying this it all depends how much you use the winch... try trademe for both options
Thanks for that. I am pretty sure that i have to get a pto box that attaches to the rear of my g/box, then send a drive shaft to the front to conect to the winch itself.
There are a few factory electric toyota winches on trade me at the mo? do you know if they are any good?
Dick wrote:Thanks for that. I am pretty sure that i have to get a pto box that attaches to the rear of my g/box, then send a drive shaft to the front to conect to the winch itself.
not sure about the toyota ones....yea how much are you going to be using this winch??? every weeknd or once in a blue moon when you get stuck?
Only once in a blue moon. I only just started getting into this stuff, and a winch is going to be mainly for the 'odd' time that i need it. im not into anyting serious, just out for a good bit of harmless fun
Dick wrote:Only once in a blue moon. I only just started getting into this stuff, and a winch is going to be mainly for the 'odd' time that i need it. im not into anyting serious, just out for a good bit of harmless fun
okay then in that case i would suggest something like this:
its cheap it has good pulling power it has everything you need to set it up on your truck. it looks like from that photo that you have a nice flat platform to mount to you may just need a couple of plates welded on so that you can bolt it on. hope this helps
Sweet. thanks for that. Would you say that the quality is good in this one? What about those 3 tonne hand puller winch things? any good for the odd occasion? Cheers.
Hi Dick I am in Rotorua and have a PTO winch for a landy that can run of the pto or the nose of the crankshaft.Also have access to a landy capstan winch,if your over this way pop in for a look.Cheers.
Dick wrote:Sweet. thanks for that. Would you say that the quality is good in this one? What about those 3 tonne hand puller winch things? any good for the odd occasion? Cheers.
the quality is not the best (it is a chinese winch) maybe for once in a blue moon it is ok but severe use and using it very weekend you would want to look at a better quality winch. really for you it would either be that or the more reliable quality hand winch.
klompy wrote:Hi Dick I am in Rotorua and have a PTO winch for a landy that can run of the pto or the nose of the crankshaft.Also have access to a landy capstan winch,if your over this way pop in for a look.Cheers.
Hi i come to vegas every day for tech. Am keen to come have a look. If you dont mind, what sort of price range are we looking for this, just so i dont end up wasting ur time. Thanks
Hi Dick just pop into 47 Vaughn road and ask for Mike.From the Polytech head toward the Airport or Whakatane and take a left of Te-Ngae onto Vaughn by Titans.Opposite John Deere Tractors.About 5 mins from Waiariki.Will be cheaper than electric winches on rip me.8000 lbs.Cheers.
klompy wrote:Hi Dick just pop into 47 Vaughn road and ask for Mike.From the Polytech head toward the Airport or Whakatane and take a left of Te-Ngae onto Vaughn by Titans.Opposite John Deere Tractors.About 5 mins from Waiariki.Will be cheaper than electric winches on rip me.8000 lbs.Cheers.
Sweet. thanks for that. Hopefully will try and see you tomoro. Thanks again.
If your not planning on using the winch to often, then your probably better off with a Tirfor type hand winch. They are more versatile than a PTO or electric winch, as you can attach them to the front, rear or side of your truck. The biggest problem with having an electric winch mounted on the front of your truck is that as you tear through the mud and crap it seeps into the winch motor, then the day you go to use it there is no go. I have made my electric winch detachable, so i can store it in the cab away from the crap, and also made front and rear receivers, so the winch can be attached to either end of my truck.
