tyre deflaters?
Petemcc
tyre deflaters?
Post by Petemcc »
well the gf got me a sweet new air compressor for my bday (good catch she is) and now all i need to do is let the air out. how does evrybody do it? i have seen the tyre deflators on 4wdbits for $70. are they any good? how do you set the pressure you want, how long do they take? or should i just go round stick something in the valve and check with a pressure guage?
cheers Pete
niblik
Post by niblik »
get the staun tyre deflators..
they work by preadjusting them to be whatever pressure you want to run by 1/4 or 1/2 turn = certain amount of psi..
they dont take that long and much better than sittin there, one tyre at a time, when ya could be chattin or drinkin coffee..
i'd say go for the stauns.
:wink: :D
Petemcc
Post by Petemcc »
also i now have 33inch goodyear mtrs on my 91 surf with 8 inch rims. what pressure would ppl suggest for off road conditions? would it be different for different 4wding???? how much clearance do you loose?
cheers Pete
niblik
Post by niblik »
Petemcc wrote: would it be different for different 4wding????
exactly....
try about 20 psi to start with... then go from there, rockier=lower pressure and vice versa...
:D
Petemcc
Post by Petemcc »
righto what about muddier and softer gravelier conditions? same thing? any time i shouldnt be letting them down???
niblik
Post by niblik »
pea shingle ya want low pressure to get as much tyre on ground (foot print), within reason of course.
as for mud etc, ya can run higher pressures to gain clearance as the ground is softer thus more forgiving.
niblik
Post by niblik »
on road ya want decent pressure... :wink:
Smurf
Post by Smurf »
I have Stauns and they are great, screw them on and then help your mates air down their tyres manually, come back and yours are all ready to go, repalce the valve caps and away you go, if only pumping them up was that quick and easy
SupraLux
Complete Bastard
Post by SupraLux »
Stauns here too... fantastic. Mine are set for about 12PSI... although thats for Simexes. Normal mud-terrains I'd probably not go much below 20PSI for risk of rolling the tyre off the bead.
They take a while - around 10 minutes from memory to get the Simexes from 30 down to 12... although in all fairmess the local garages air pump takes that long to get them back to 30 again :)
Steve
Petemcc
Post by Petemcc »
just ordered some from 4wdbits. cheers for the advise
Pete
Return to “Tyres”
