Snorkels & Waterproofing
wjw
Post by wjw »
Anyone kown where I can get one and how much ish it would cost for a snorkel for a 93 3Ltr TD Landcruiser Prado?
Oh and also anything else I should look at waterproofing...
Who knew Prados could fly?
tomsoffroad
Flopsie
Post by tomsoffroad »
You can buy those Airtec snorkels for about $300. I can help you get one up here if you need me too :D
Or you could get one made out of 3 inch exhaust tubing and just buy the air ram to go on top.
You shouldn't have too many problems with any other electrics that I can think of.
Does it have a viscous fan on it? Or is it rigid or electric? You don't want a rigid fan if you are crossing water. They tend to overheat once the water snaps off all the fan blades! :? :?
Guest
Post by Guest »
As Tom said, they should cost you about $300 from any of the main 4WD outlets for an Airflow brand. I looked at importing them, but they cost around $260+GST to import and I refuse to make $10 on something like that - its just not worth it so I let the 4WD dealers sweat for their dollar and buy them from them as req'd - you can see them as low as $280+ in some outfits...
Waterproofing - diesels are pretty waterproof normally - just be VERY careful when fitting the snorkel to make sure all the joints are fully sealed - even use a bit of RTV around each pipe connection before doing up the hose clips to make sure. It takes less than a teaspoon of water to make most diesel engines into very expensive boat anchors.
electric fans are a good way to stop the water-thrashing - but fit them with an alarm so that when you manually shut them off for river crossings you know they are off - forgetting to turn them back on can be just as bad as giving the motor a lung full of water.
regards
Steve
SupraLux
Complete Bastard
Post by SupraLux »
that was me, btw... forgot to log in :oops:
regards
Steve
wjw
Post by wjw »
Cheers guys, will be down the workshop tommorow so will see if I can get one at distri prices ;)
wjw
Post by wjw »
Dude next door.... wasn't in, so will try again next week...
