Need some standard springs (not sure about the rear) but i know the front ones will fit in my disco and give it 3" of lift .....anyone got some lying around they don't want???? must be very cheap
Yip fronts. Cost me $230 would like my money back.
Have only been used to hold the front of my safari up for the last couple of months so havent seen any driving. found some 5" Safari springs to replace them with.
doddzee wrote:Yip fronts. Cost me $230 would like my money back.
if only i had $230 .....I think they might be a little big actually, if i put them in that would mean i would have 7" of lift + im keeping my tyres now as i have just bought some rims to suit the nissan diffs....Il just do a bit more of a guard chop and keep it the way it is...... got my new rims last night on trademe for $209 came with road tyres to....might get some shitty rims l8a and use them as road tyres
Dont run alloys! Get steel rims all you will do is hit a rock and bend or crack the alloys. At least when you hit a steel rim on a rock you can smack it straight, after you dent or bend and alloy its pretty much through away. You can get new steels at tonys for $65ea
now u tell me ............the'l do for the moment....its just to get it rolling pretty much
Complete set?? 80 Rears wont fit the GQ coild hats. You will need to get some 2" Gq rears to match the 80 series fronts.
Or i can sell you some 4" GQ Rears to and those 2" OME 80 Series springs and give you that 7" of lift!! Then you can fit 37's and probly end up on your roof
