Wheels for LN130 Surf with IFS
NA_Drifter
Post by NA_Drifter »
Well, I wonder what is the offset wheel can be fitted to LN130 Surf with IFS? The factory chrome steel rims are 15x7 and seem like + offset? I have 15x8 with -28 offset at the moment which off a Pajero and is fine as I have fitted flares on the Surf.
What to look out for as I'm looking at getting another set of rims with mud tyres on, prefferbly with neg offset. What will fit and what's not and what to look out for as I often heard of wheels suitable for IFS and other for Solid front only...
thanks
Keith
LN130 Surf- 2JZGE living in there now!
SupraLux
Complete Bastard
Post by SupraLux »
possibly what you've heard is that 15" IFS rims will not fit the solid axle trucks, as the offset causes them to sit in too far and the steering TRE sits the inside of the rim on the front.
Solid axle Hilux rims (big neg offset) fit fine on the IFS trucks and give a good stance for mud tyres - although you will need flares for them, and a cert if you intend to run them on the road...
Got any pics of the conversion you did?
Steve
NA_Drifter
Hi Steve,
Thanks for the reply. I have got cert with flares on mine, so should be sweet. Basicly, if I want neg offset wheels, i have to look for those of solid front axle Hilux, Pajero, Safari etc?
Haven't taken any picture yet, but I'll take some and maybe post them up at the "Project" section soon..
ALso, for bullbar, nudge bar etc, what others years, model or make that's also compatible with my LN130? or doesn't need major work to fit? The only thing I need to watch out for at the moment is I have already got 80mm bodylift, so some will not fit... might have to make some braket up...
