bead lockers
spanky
bead lockers
Post by spanky »
where in central nth island would be good place to get some bead locks put on some 15x8 steel rims i have got for scudo2, and what sort of dollars should i be looking at . cheers
vaughan
bj
Post by bj »
whats your phone number i think i know where there is a couple
cheers brent
monstr
Post by monstr »
Hi,Try either mike at Swages in Auck ph 5706969 or Warren at 4wd bits ,hes got a advertisment on this forum...Cheers
spanky
Post by spanky »
cheers for that i will ring them tomorrow, brent ,number is 027 249 3256 . cheers
vaughan
Terry
Post by Terry »
Brian Howat did mine - he's in Petone (Howat Engineering).
spanky
Post by spanky »
thanks for that terry, what did yours cost?
vaughan[/quote]
mroffroader
Post by mroffroader »
spanky wrote:thanks for that terry, what did yours cost?
vaughan
[/quote]
apparntly he charges $100 per rim :?:
Terry
Post by Terry »
Yep, mine cost $100 a rim - be aware that that's just the machining and welding (ie: cut the outer off on the lathe (?), weld in the beadlock plates). You'll have to tidy up the weld a bit and sort out sand/bead blasting and paint or powdercoat. No big deal, took me a weekend to tidy afterwards. I stripped the whole wheels, in retrospect next time I'd just mask and blast the 50mm beside the weld and use a rattle can to paint (or have the whoel setup powder coated).
doddzee
Is Doddgee
Post by doddzee »
Speaking from experence once you get a set run them tubeless. Check the bead of weld for any spots that look like the might leak and put a bit of sealer there if required. Brians lockers are usually very good only 1 of mine required a small amount of sealer.
Running them tubless you will not have any trouble with tubes chaifing. Also if you get a small puncture you can usually just chuck a bit more air in it and keep going where a tube dumps its air very quickly.
MWB V8 Safari Ute
spanky
Post by spanky »
cheers for that guys,i like tube less for the same reason and i can fix in the bush, i will be powder coating the wheels as my inlaws run mount powder coaters at the mount so lots of my new beast will be powder coated. cheers
vaughan
Terry wrote:Brian Howat did mine - he's in Petone (Howat Engineering).
I don't think he does certifiable 36 bolt bead locks if your going to use the truck on the road?
doddzee
Is Doddgee
Post by doddzee »
My howat 24 bolt beadlock rims were certified 2 days ago :wink:
MWB V8 Safari Ute
Terry
Post by Terry »
There's an outfit in Alkd suggested that only 36 bolt beadlocks be accpeted for certifying (they do 36 bolts), but I don't think they were taken up on it. I think it's still up to the individual certifier...
:?: you never know, havent read any of the LV standards for a while but I remember reading that they required bolt spacings at every 10 degres, I'm sure that's supposed to work out to 36 bolts? :scratch:
doddzee
Is Doddgee
Post by doddzee »
Yeah i think thats what the rules say but its also up to the certifiers descresion if he wants to put his name to them.
MWB V8 Safari Ute
swampa
Post by swampa »
my certifier wouldnt cert my beadlocks brian made, he said as well every 10dg, still drive them around everywhere as they are only 8inch rims and my cert plates allow for 10 inch rims
Terry
Post by Terry »
Ow - who was your certifier? need to do mine soonish :(
doddzee
Is Doddgee
Post by doddzee »
Terry wrote:Ow - who was your certifier? need to do mine soonish :(
Answered via PM Terry.
MWB V8 Safari Ute
shrmin
Post by shrmin »
If you're certifier has certed them he's wrong. We've done a lot of research into this for the Winch Challange rules and the head of the LVVTA has said that since their is a spec that's what they must be cert'ed too. You may have issues with insurance if you have a problem. And yes I do make the 36 bolt ones but that's not why I'm saying this.
Terry
Post by Terry »
ouch. I may have to build the "offroad only" verison of the truck sooner than planned. Damn.
doddzee
Is Doddgee
Post by doddzee »
shrmin wrote:If you're certifier has certed them he's wrong. We've done a lot of research into this for the Winch Challange rules and the head of the LVVTA has said that since their is a spec that's what they must be cert'ed too. You may have issues with insurance if you have a problem. And yes I do make the 36 bolt ones but that's not why I'm saying this.
So anyone with the 24 bolt beadlocks will not beable to compete in winch challenges even if its on there plate??
Was your company the one consulted when those rules were put in place??
MWB V8 Safari Ute
shrmin
Post by shrmin »
They can run the 24 bolt if they were certed on that vehicle before 1st September 2003, if they are certed after that date they are not legal. Yes I was consulted.
Terry
Post by Terry »
{betraying my total ignorance here} do Winch Challenge trucks need to be road legal? - just for interest as i can't see myself being able to afford to play anyway...
shrmin
Post by shrmin »
Yes they must have a W.O F current within 28days for every comp.
monstr
Post by monstr »
Yes All Winch trucks must have a WOF no more than 28days old, Reg ,and a min of 3rd party insurance...Cheers
4WDbits
Post by 4WDbits »
Not to mention Low Vol Cert to cover all the mods, and the scrutineers check it all which is how it should be. On occasions things get passed which shouldn't, but then sh?t happens.
Ben
Post by Ben »
Terry wrote:ouch. I may have to build the "offroad only" verison of the truck sooner than planned. Damn.
:idea: Or get out your drill and put in another 24 holes.
That is one way to make "non-certifiable" 24 bolt wheel into certifiable 48 bolt wheels.
Ben
safari_mulisha
Post by safari_mulisha »
lol if your gonna do that use a drill press
safari_mulisha wrote:lol if your gonna do that use a drill press
even better at 24 new holes x 4 rims = 96 new holes get someone else to do it for you :wink:
safari_mulisha
haha fair call..
i used to build trucks and end up using a mag based drill for hours on end days at a time drilling holes in chassis rails
