I need a new crank chaft gear that goes on the end of the crank shaft out side the engine. need to replace the crank seal but the gear is stuck on and will probably have to destroy it to get it off.
also need a new water pump and cam belt tensioner if anybody can get either of these cheap.
Cheers Pete
