I have a Hilux Surf Automatic which recently stopped changing gear for me.
If I manually change from low to 2nd to drive all seems ok.
The overdrive light comes on but this too seems to make no apparent difference.
Also if I kick down the throttle it doesn't change down.
Just wondering if anyone has come accross this and has a remedy.
I was advised to check the transmission fluid level but this is fine, I will however change the fluid soon to see if it makes a difference..
Any advice or suggestions would be appreciated.
Thanks in advance
Hilux auto transmission won't change
Bad News
I would take it down to a mechanic and get it checked. I hate to say it, but my dad had a problem that sounds fairly similar, wouldn't change gear and the O/D was crapping out, and that was the end of that gearbox. He had to have another one put in.
So I would take it down and get it checked.
Kent
Kent
