hydraulic line as fuel hose?
I have some left over 400psi 3/8 hydraulic hose i was thinking about using as fuel line in my diesel cruiser. Bad idea? does it disolve it?
- truck-fixer
- Disco-Blue
- Steve_t647
Grab a small section 15 - 20 mm of hose and stick it into some diesel (ice cream container) and see what happens, I think Hydraulic fluid is more corrosive than diesel but would tes it for a week.
You want to cut it open and compare it to a new cut open section also put a filter on the end of the line before the pump and engine in case it does perish.
Good luck, and it is the additives that usualy cause the issues not the diesel itself.
- Armourguard
- Armourguard
