Holden 3.8 Project
ToySurf
Holden 3.8 Project
Post by ToySurf »
Is there a New Zealand company that makes bell housing's to fit between a holden 3.8 V6 and a hilux g52? Or will i have to buy it from Oz? And how much does it cost?
nzhunter
Post by nzhunter »
Use Marks Adapters they have all the bits for the conversions 4WD UPGRADES in Christchurch sell them Ring them on: (03) 365 8800
Dan
spankmeister
Post by spankmeister »
I have my Hilux in at 4WD Upgrades having a Holden V6 fitted at the moment. The Mark's kit from Aussie covers everything. They have done a great job, though haven't got it back yet due to running rich at idle.
Mike - PM me for phone number
* LN65 D/Cab * Snorkel * 50mm Lift * 33" Mud's * 3.8 V6 *
philux
Post by philux »
looking into doing the same thing on my ute,
http://www.marks4wd.com/products/engine-trans-conversions/toyota/hilux/hilux-index.html
I think they are a tad expensive...but you can get everything off them to do the conversion.
Im thinking of going dellows (ex oz)
$950 AU (from memory) think it included bell housing, clutch realease bearing, clutch fork and some other bits. The mechanic next to our wholesaler is looking into it for me and he reckons, 5-6k pretty much drivein - drive out, and that might of been freshing up the gear box a lil
Phil
ToySurf
Post by ToySurf »
Cool thanks for the info guys.
mudhaw
Post by mudhaw »
Have fitted one before with marks adaptor kit pice of cake, has everthing.
Including wiring harnes that makes all the factory gadges work (except rev counter) just plug in and play
gomulletgo
Post by gomulletgo »
Correct me if I am wrong people, but wouldn't he be better off to get the stronger W56 gearbox first? as it bolts to the existing transfer case and is apparantly 50% stronger than the G52.
holden 3.8 to W56 gearbox adaptor
instead of holden 3.8 to G52 gearbox adaptor
Just thought that being a torquey engine and possibly running big tyres would be a killer for that gearbox.
hope that helps :D
hosehustler
Post by hosehustler »
W56 and G52 bellhousing is identical, so either will fit the Dellows or Marks kits.
The G52 tranfer case is shifted differently than the W56 though :!:
You can use the W56 transfer case on either box, but the G52 transfer case has to be modified to work on a W56 box.
Best idea is to use a W56 box and trans case complete, or a G52 box and trans case complete :wink:
The W56 is stronger overall (don't agree with 50% tho :shock: ), but they do blow reverse easily (as I have found out the hard way).....I'm now back to running a G52 with twin w56 trans cases linked together with a Marlin crawler, had to make a small cover for the G52 where the trans lever used to come out, but that's real easy
I hate signatures
doddzee
Is Doddgee
Post by doddzee »
If you go for the marks kit make sure that the engine adapter has parallel faces. I know of 4 kits (1 being mine) that were not.
mudhaw
Post by mudhaw »
Not sure what you mean about the G numbers but the 5 speed deisel gear bag is stonger than the petrol gear bags. The 4 speed petrol ones go pop real easy
