W56 GEARBOX WANTED
- MAHINDRACJ4A
W56 GEARBOX WANTED
hey guys im after a w56 with transfer case
gomulletgo
- MAHINDRACJ4A
- MAHINDRACJ4A
That will be a G52 box Turoa... and it will bolt in place of the W56 the only issue is the transfer case shifter isn't in the same place... if you've got a buggered gearbox Mahindra then the transfercases can be swopped from your old one to turoa's box to keep the shifter sticking up out of the same hole
Cheers Reece
Cheers Reece
- MAHINDRACJ4A
De-Ranged wrote:That will be a G52 box Turoa... and it will bolt in place of the W56 the only issue is the transfer case shifter isn't in the same place... if you've got a buggered gearbox Mahindra then the transfercases can be swopped from your old one to turoa's box to keep the shifter sticking up out of the same hole
Cheers Reece
i was looking to get a 4x4 manual box to put behind the lexus v8 in the mahindra
Based on the size of the mahindra I'd sugest an early 40 series 4 speed they are a real short box thats resumbly strong ... theres more than a few running behind 350 chev's
The shorter box will give you a better rear drive shaft angle after you've lifted it
PM Wopass, Niblick or one of the other 40 series nuts they'll give ya the details on size
Cheers Reece
Oh just remembered Wopass is freezing his ass at the moment
