Fire Extingishers
All aspects of safety with 4wds from proper mounting of tow hooks to recovery situations.
dazza85
Fire Extingishers
Post by dazza85 »
Do you have one in your truck.
If so where have you mounted it ??
basics
Post by basics »
yes, i mounted it in the back but will all the pigs i throw in the back it fell off over time, get yourself one with a metal bracket, mine was plastic
albundy
Rolly Polly
Post by albundy »
I've got two mounted on the inside of the rear barn doors. I am about to mount one between the front seats to comply with winch challege rules.
Al
ext
I 've got to figer that out too for my clubs winch challenge next weekend
basics
Post by basics »
how many do you have to have for winch challenge?
of just one in the front?
ext
the rules state they have to be within easy reach of the driver or co driver ,
1 2kg or 2 1kgs, as listed
jdeburgh
Post by jdeburgh »
I've got 2 x 1.1s - one under the front of the drivers seat and one in the rear just inside the hatch.
-Vehicle: Rangie - 4 Wheels, 3 doors, Engine, Gearbox, other whirly bits, Steering wheel, Radio, Seats, Pedal that makes noise, pedal thats stops it, and pedal that helps stop the crunching noise when using the gear lever.
http://www.feilding4x4.org
Not much room in my singlecab for anything but it sits behind the drivers seat with all the other junk and its the first thing that falls out when you flip the seat back :?
Ryan
Post by Ryan »
i have one mounted between the front seats on the zuk.....
4wdnuts
Post by 4wdnuts »
i have a 1kg on passengers side foot well
also have another one mounted in the tool box on the back.
kiwipete
Post by kiwipete »
Mine's in the back of the truck, would like one in the front, but there is a lack of space.
Ph 0212078472
Disco-Blue
Post by Disco-Blue »
Put mine in the glove box today, realised upon reading this that it was just sitting in the garage when should have been in my truck.
wjw
Post by wjw »
I have a 2kg, in the rear footwell, easily accessible from the front. plus a 1kg in the boot (that needs replacing)
Who knew Prados could fly?
got to be real careful about how securely they're fixed to the vehicle coz the last thing anybody wants is a 1 or 2kg missile bouncing around the inside of the cab in a roll over or accident :?
Return to “4wd Safety”
