anyone got safari upgrade bits they wana sell????
For all Nissan related topics
mudhunt
Post by mudhunt »
hi ive just bought a 91 swb that im setting up for off road. At the moment it is bog standard. Well ive got 33"s for it but ill be wanting to go to 35s once some work is done. Im interested in any parts lift springs, shocks bullbars winch snorkel. etc drop me a line if you have something you wish to part with. Im in chch. Also any do and donts would be appreciated
Shane
Post by Shane »
I have some EFS 100mm(4")front springs (215lbs)
well fit LWB/SWB GQ nissan Safari's.
These are a soft spring to help front articulation.
I brought these new on 3/6/06
$200(front springs only)
Springs still in vehicle,I'm in chch also so you could have a look if your keen.suitable for 35's which is what I run.
Shane
1nzsafari
safari stuff
Post by 1nzsafari »
hi may have ARB front bar, m8000 warn winch ,homemade rear bar, and 50mm bodylift , 50mm springlift all depends if guy comes up with the money he has untill the 20th of the month to buy it,He dosnt want any of the above on it Cheers tim :D
mudhunt
Re: safari stuff
Post by mudhunt »
1nzsafari wrote:hi may have ARB front bar, m8000 warn winch ,homemade rear bar, and 50mm bodylift , 50mm springlift all depends if guy comes up with the money he has untill the 20th of the month to buy it,He dosnt want any of the above on it Cheers tim :D
Gday Tim id be very inerested in that gear im a cash buyer and will not muck you round. Im very interested in front bar and winch. How old are the springs?etc is it likely that the guy will come thru with the coin as im looking at a few other bars and so on at the moment. Thanks very much Tim for the reply. You can text me on 0212220852 jason
mudhunt
Post by mudhunt »
Shane wrote:I have some EFS 100mm(4")front springs (215lbs)
Shane
Thanks shane but i dont want to go that high with the suspension lift max 3" as i use it alot on the road. Thanks very much for the reply
1nzsafari
Post by 1nzsafari »
Hi again tony from chch came down today paid for it,plus xtra for the after market stuff on it( after spending last weekend takeing it all off had too put it back on again minus the springs just threw them in the back) so if you see a red /gold gq safari with twin pipes out the back,on 35s baja claws which will prob be bald by the time he gets to chch ,left here wheel spinning in 3rd gear say hi to him , said he was going to join up here cheers tim
