Steering Box
brakes-shocks-lockers-etc
JAMUBA
Steering Box
Post by JAMUBA »
Hi Guys
Got a problem with me power steering box, I need more power :twisted: .
Its of a toyota crown and its not doing the job when the tyres are low.
Any idears for a replacment.
Chris
turoa
Pyro Junior
Post by turoa »
Ive got a GQ patrol box in my land rover. I dont know how well its going to work yet though :?
might need to consider what pump your using as well, I'm running a chev pump onto a cruiser steering box and it just makes the grade, the last chev pump I had didn't cope very well at lower engines rev's.... when you really need it :?
JAMUBA
Post by JAMUBA »
Is pump or box which gives more power?
Chris
Steve_t647
Post by Steve_t647 »
It is the pump, but the more pressure you add here the more likley you can blow the power steering seals, lines and pump.
Here is a mod you can do to a standard pump this is a chevy example but the toy one will be similar from memory, this helps at lower rev's at higher revs you may loose some feel.
http://westtexasoffroad.homestead.com/p ... ering.html
Good luck, and I am sure Sadam will probibly give this a go and see what results he gets if he still has the old power steering pump. :wink:
