Fitting Snorkel to V6 Surf.
Bacon
Newbie
Newbie
Post by Bacon »
Has anyone Fitted a snorkel to a Toyota Surf 3Lt V6 if so what make and what changes need to be done with the factory air cleaner or in the engine bay ?
padero
Post by padero »
hi bacon.. ive jst got my surf and a snorkel will be the 1st thing to go on i have a V6 aswell .. from looking at cromcrusiers if i remeber right we have to move the air box upwards and move some of the electrics , im sure if crommie reads this he will let us know what we have to do.. have got a snorkel yet ? if so how much did you pay for it ?
ad
holdenyip
Stropper
v6 snorkel
Post by holdenyip »
hi fellas, jason here. im looking at gettin meself a snorkel for my 92 v6. just spotted your thread and wondered how yiz got on with buying and fitting yours. any info would be much appreciated. im ready to buy now and just researching the project....cheers guys.... :scratch:
padero
Post by padero »
hey, when i put mine on i found that the pipe that came with mine was too short and i had to buy a new piece, part from that was ok.. the airflow on my surf wasnt as nice to put on as the air tech on my old pajero.
ad
Put the snorkel on
the crank fell out the bottom of the engine when my mate hydroliced his V6 :scratch:
mroffroader
Post by mroffroader »
Sadam_Husain wrote:Put the snorkel on
that was up the oronga's wasn't it becuase he didnt properly seal up the airbox or something :? :roll: :D
Petemcc
Post by Petemcc »
i put one on my v6 surf. was easy enough, didnt have to move anything etc. just get lost of silicon!
Pete
penetrator
Post by penetrator »
I put an airflow one on mine by myself - i managed to get the snorkel and all the bits from a wreckers where i saw a V6 surf with it on for $150. The air box that I got was modified with a piece of right angle pipe plastic welded to the airbox so that when the hose comes through the inner guard it connects straight into it. Apart from that just be careful marking the hole in the guard before you cut it and silicone all the joins in the air intake system - i used the black ATV silicone not the clear white stuff
holdenyip
Stropper
Post by holdenyip »
sweet as, hard out looking for a good deal at the moment. having the time is the issue. i noticed that the intake hole on the air cleaner assembly is jammed right in the corner behind the headlight and was wondering if i needed to re-mount the air cleaner, or do the kits allow for this :?: also if anyone can help with where i could get a good deal on a kit(new or second hand)that would be greatly appreciated....cheers guys. :wink:
V6BRM
Post by V6BRM »
Hey
i gt snorkel on my V6 surf and u jst hav to remove the plastic bit where the air intake is behind the light(one mayb two bolts from memory) and u r left wif a hole in the air intake box which is where u put the bit of hose. like every1 else says use heapz of silicon especially around where u clamp the hose to the moulding of the snorkel inside the guard cose it is a right pain to try and do later lol
