Thermo fan set up
billyvanboheman
Thermo fan set up
Post by billyvanboheman »
I'm in the middle of an electric fan mod and am looking for some info on which way the wiring should work.
I have inherited a fan and thermo switch set up out of a Mitsi, what I need to know is does the thermo switch work by closing the circuit on a ground wire, or is it making a live wire when closed?
I can rig it up and test it, but would prefer to get an opinion before trying to fry it!
dazza85
Post by dazza85 »
If the thermo switch is a single wire it will go to ground, if it is a 2 wire it can go either / or ...
I'll do a sketch when I get home then others can tell me where I've gone wrong then we will both be better off. :lol: :lol:
billyvanboheman
cool, mine is a two wire switch, and I stick to my moto, I HATE auto electrics :!: :evil:
BIG_BOY
Post by BIG_BOY »
heres how i would do it it gives you safty added cooling when desired & stops water from rivers going every were when need but is still unable to be for got in after the river is over
try this
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
billyvanboheman
I was half way through drawing a pic of my own, but it was not as flash as yours, I am on the same track, but a little less thorough in the switching department.
I have a rocker switch mounted in the console between the seats, so that when the fan is switched off it runs a big red flashing light above the temp gauge.
I've never got the whole relay thing though, so hadn't planned on one, can you fill me in on it, in layman's terms?
dazza85
Post by dazza85 »
Big_boy had the right idea ... but his hot weather override switch was in the wrong place ...
I'm picking thats why he pulled it ...
The relay handles the current load of the fan (or spots, horns, etc)
this means you can use lighter wire and smaller switches to control the equipment.
billyvanboheman
dazza85 wrote:The relay handles the current load of the fan (or spots, horns, etc)
I see, so heavier cable for the power to the relay and onto the fan, then lighter cable to run all the switching :?: :roll:
BIG_BOY
Post by BIG_BOY »
yeah that was why i took it off but its back now all fixed
also a relay in the right place will add 20-35% more profamance to a eletric fan over a switch that flicks the current
BIG_BOY
Post by BIG_BOY »
yep you got that way the cables for the power are shorter & have less joins breaks so there is less V.D. so it fan gets more volts & current so it works better
Mattman
Post by Mattman »
If the joins are properly made and the right size wire is used there will be no voltage drop.
Running 20-30 amps through a switch though is not a good idea, you will burn it out quickly and also have a big point of failure.
Also you want to use a normally closed relay if possible to power the fan, that way if the sensor or your switch fails the relay will default to closed and will power the fan.
If your sensor doesn't allow this then you need to use two relays, use the first relay to invert the signal from the sensor so you can then drive the second relay which drives the fan.
Matt.
niblik
Post by niblik »
bah..
electrical this... join that.. connection voltage whats-it-ma-jiggy those....
i read it, but all i'm makin out is 'wa wa waaa wa wa waa waaa wa waa'
viscous fan! now thats where its at.. :wink: :lol:
kiddin.. nice form dude.. what about the disco dash light? gonna update this thread about that? (in the background with the smoke machine... doof doof doof doof doof... ) :roll: :lol:
dazza85
Post by dazza85 »
I hope Big Boy doesn't mind I pinched his pic,
I like his idea of a pushbutton that your passenger holds down but I often don't have one. They often seam to bail on me ... I'm not sure why :? :?
Any way if you replace the pushbutton with a 2 way toggle ( it has 3 tags out the back) when the fan is not on the light is.
If this don't make sense pm me your phone no and I'll see if I can make it clearer
billyvanboheman
Does any of the Electricery experts see any issues with my idea for the Electric fan wiring.
I take on board the idea about the normally closed relay, but have gone with the open option.
Any input appreciated.
dazza85
Post by dazza85 »
That looks spot on.
wjw
Post by wjw »
This is what I'm doing. No light but I have On - Auto - Off, using heavier wire, no relay for the switch only for the Thermo control module..
Who knew Prados could fly?
BIG_BOY
Post by BIG_BOY »
WJW you cant have an auto with out a relay the temp senders handle 1A max theres no way you can draw 20-35A thro them
wjw
Post by wjw »
BIG_BOY wrote:WJW you cant have an auto with out a relay the temp senders handle 1A max theres no way you can draw 20-35A thro them
Oops sorry yes .. hold on I'll change it.
BIG_BOY
Post by BIG_BOY »
WJW that still wont work id sujest you go with the plan me or dazza have put up cos at the moment your relay wont trigger & also when you bypass the relay you will be putting alot of current thro the switch witch isent a good idear as that will creat a V.D. in the switch normaly & also you have know way of putting a light in for when its off so if you knock it will be all over for you motor
Return to “Tool Shed”
