Sticky clutch
- suzuki_mike
- Driver/Navigator
Sticky clutch
Just wanting abit of knowledge from the ORE crew. My clutch has started sticking everytime I get in abit of mud. The last time it happened it fixxed itself on the motorway. Tonight it didn't. By sticking I mean it wont engage *spelling?* so I have to start it in gear and ram it in to the next gear at the right speed
Is there a seal thats meant to stop this? I've try spraying alot of CRC round the cable but I did nothing. All help and tips would be great. Thanks, Mike
- suzuki_mike
- Driver/Navigator
- Steve_t647
- suzuki_mike
- Driver/Navigator
Cheers guys. I'll have a good look tomorrow. Yeah it's my first car, know a wee bit but not all that much. So it's okay to spray abit of water in there? Sealing it off or moving the breather is probably what I'll be looking at.
- suzuki_mike
- Driver/Navigator
Ummm from memory there should be a 1/2 round bellhousing cover on the bottom of the gearbox where it connects to the back of the motor with 2 easy bolts, take this off and have a look...if there is mud everywhere give it a clean.....can you get to the release bearing mechinism.....does this need a grease?
When you take the bolts off take it easy if they are rusty they will snap
could try PM'ing lilpig on here he would know more
- suzuki_mike
- Driver/Navigator
- Rotazuk
You guys have it right . Take the bottom cover off and for a quick fix get the hose and give it a good spray out , work the clutch etc and spray some more . This is not good for the clutch etc but beats taking the gearbox out and probobly changing the clutch anyway . Then take the zuk for a good drive and dry it all out . Should be sweet until the next big mud hole you sink it into
Chris
Chris
- Dr_PC
Rotazuk wrote:You guys have it right . Take the bottom cover off and for a quick fix get the hose and give it a good spray out , work the clutch etc and spray some more . This is not good for the clutch etc but beats taking the gearbox out and probobly changing the clutch anyway . Then take the zuk for a good drive and dry it all out . Should be sweet until the next big mud hole you sink it into![]()
Chris
My old 413 I use to pull the box every 12 months to clean the shit out and that was with sticking the hose in the side of the bell housing after every run
- suzuki_mike
- Driver/Navigator
Some pics on here
http://www.trademe.co.nz/Trade-Me-Motor ... 1.htm?p=15
http://www.trademe.co.nz/Trade-Me-Motor ... 2.htm?p=17
suzuki_mike wrote:What exactly is the bell house? and how do I get to it? Bit more of a newbie than I thought
Find the sump of the engine looking from the front of engine. At the very back you should see where the gearbox meets the engine. There is a thin tin plate, - half round. There are 2 10mm bolts that hold it on. If it hasnt been off for a while then it will need a gentle prise with a flathead screwdriver. Should be obvious once take it off if there is major crap in there. I replaced mine with a new one from Suzuki. There should be a rubber/foam seal along the top, this breaks down over years of mud and oil.
The first part of the gearbox is called the bellhousing, this houses the clutch, pressure plate, flywheel, clutch fork etc. This will be where your issues are happen. At the base of the belllhousing you should see 2 open slits. They face too the back. This is where alot of crap gets in too especially when reversing through mudholes. Make sure they are clear though so crap can get out
- suzuki_mike
- Driver/Navigator
- suzuki_mike
- Driver/Navigator
You might want to try those 2 bolts first before you take the thing in to the shop, they'll probably be wanting to remove the gearbox to get the clutch out to replace it or clean it up.
If you end up taking it into the shop take it to G.Guy motors (your in Wgtn arent you), they're not the cheapest but they specialise in all that sort of stuff and they may have a few tricks up their sleeves for an easy fix
