Boys, I need a pair of 5m upper engine mounts for a 7m conversion.
Anyone out there got a pair they wanna sell me?
Need a 3y or 5m flywheel too
Wanted: 5m motor mounts,3y or 5m flywheel
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
- MAHINDRACJ4A
3Y fly wheels are different to M serise altho 18R & 18R-GU are the same 18R-GU is lighter tho
to use a 3Y fly wheel u will find its slightly thiner & will up set the thurst berring also the ring gear is ither a different height or different teeth count or picth ither way its not a good match as it leaves the starter only touching a minumal amount of teeth
& yes i found this the hard way
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
BIG_BOY wrote:3Y fly wheels are different to M serise altho 18R & 18R-GU are the same 18R-GU is lighter tho
& yes i found this the hard way![]()
pretty sure you use the washer from the flexplate to space the flywheel ot from the crank, I'll talk with Suprasurf, he'll know, hes only done a million of these swaps
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
