Wanted: Wide Hilux Axle
muddy_munke
Post by muddy_munke »
Howdy,
Am after a wide rear hilux axle. Found in IFS surfs I am told.
Don't need diff heads or anything. Just axle.
Not to expensive hopefully :cry:
Pm, Reply, Ring or Txt 027 3380174 Chch area...(ish)
Cheers Daniel
SupraLux
Complete Bastard
Post by SupraLux »
Don't forget to get the bottom plates as well... they have the holes wider apart to suit the larger tube that the wide axle has... unless you are planning a u-bolt flip...
Oh, and the handbrake cable... you need that too as its wider... unless you're disc-brake converting it.
Steve
muddy_munke
U bolts brought, Disk brakes done. lol Cheers though. Pity ya don't have any bits I can use :wink:
Daniel
muddyhilux
Post by muddyhilux »
mite not be any help but got a rear diff assembly,drum to drum,minus diff head with hand brake out of a 1987 yn61 surf(ifs),could even have the springs n u bolts etc if ya wanted,was only gna ask for 150,but i am in auckland,altho u may kno sumone in frieghting to help u out
muddy_munke
Cheers for that. its what im after but not worth the frieght, probably be more than the axle itself. Cheers for that though. Daniel
SupraLux
Complete Bastard
Post by SupraLux »
muddy_munke wrote:U bolts brought, Disk brakes done. lol Cheers though. Pity ya don't have any bits I can use :wink:
Daniel
Not the U-bolts - the plates they bolt to... or have you bought round u-bolts for a flip?
I might actually have a spare here to be honest... I have one housing but I'm one stub-axle short... I was thinking about that the other day, and I suspect from memory that Mike-of-the-bouncing-bewbers may have it at his place... so in a stretch I could possibly have a setup for you... PM Mike and ask him about Steves stub axle... could be worth a go...
Steve
muddy_munke
Yeah i brought new U Bolts for the flip. Getting plates sorted now. Which mike? There are so many it seems. I don't really know who is who. I'm keen though, my axle is just to skinny. How much where you thinking? :oops:
I can contact Mike when I find out which one lol.
Thanks heaps Steve.
Daniel
SupraLux
Complete Bastard
Post by SupraLux »
The mike called "mike" - site admin and owner Mike... just send a PM to 'mike' :)
$150 for the complete axle is about the going rate - rest assured the money will go to a good cause... I'll buy steel and post pics of me bending, cutting and welding it for you all :)
Steve
muddy_munke
Sounds good to me. I have PM'd 'Mike' so hopefully he has the goods.
If so is it ok to grab it this week some time?? Ill grab the other parts of Mike if all goes to plan?
Cheers Daniel
