Here's a doozy for you!! I had the same problem in my falcon.
Check all your stop light bulbs!!
Most cruise controls wont work if there's a stop light out, as they use the stop circuit to dis-engage the cruise when you hit the brakes, and if it "see's" a bulb out, it "thinks" it might not disengage when you brake, and therefore doesn't allow it to work........ (Note the dumbass speak, that's the only way I could understand the sparky when he explained it to me, so that's what you get too!!
Cost me $126 to find that out..........
