92 Navara Ute Problem
Shayne
Post by Shayne »
Gday guys I have a 1992 D21 Navara Ute, Ive done a few mods but engine standard..
Its the 2L Petrol and when i do a rarther steep hill climb the thing starts to starve itself of fuel and starts cutting out.
Its only done 77,oookm and never does it on hills on the normal road, just steepish inclines offroad.
Any ideas on how i can fix, or anyone heard of this before.. Its a carby job not injected also... Maybe a surge tank is required?? Its embareesing cause the other day it did stop and one pulled to the flat up top, took a few pumps of accelerator and a few key turns to restart..
Thanks heaps chaps
tgaguy1
Post by tgaguy1 »
I would check the float level in the carb is correct first off.
Shayne
Post by Shayne »
thanks TGa guy, sorry really dumb Q is that something i can do?? and how
tgaguy1
Post by tgaguy1 »
Easier to get a manual out of the library, as there will be little piccies to use to guide you. With a fairly basic tool kit you can check it yourself.
Where abouts are you shayne? Someone on here with a bit a mech knowledge maybe able to hep you out by showng you how to do it first time.
Shayne
Post by Shayne »
Palmerston North mate :)
Thank you sooo much for all your help, if anyone could help me out that would be great
