Bullbar and mounts for Escudo/Vitara
For all Suzuki related topics
lneil
Post by lneil »
Note: this bar and mountings would be equally suitable for a Sherman tank.
Thanks to SMURF for giving me the bar off his old Surf to use as raw material. The top bar and droppers were a great starting point, much appreciated Keith. A huge thank you to Kevin and 'Tash for coming up with all the detail and ideas, then doing all the work. All I had to do was watch, learn, take photos and play with the grinder.
We (they) removed the existing tissue-paper bumper and drifted a close-fitting length of round bar the full length of the front cross-tube.
Then used 100/80 heavy angle for upper support mounts, using the existing mounting holes in the chassis rail front-ends.
Trimmed the angle to fit and positioned the bar, then welded the angle in place.
Obtained two tiny little nuts/bolts and welded the nuts into the ends of the round-bar cross-tube.
Mounted brackets to bolt lower bar section to cross-tube, bolted in place and welded to bumper. (Excuse the hacked box-section bracket, but the lower section was all we had available, and was too short for the ideal set-up. If you made one from scratch, you'd have it the right length and only have to use a piece of flat bar for a bracket.)
Finished welding and cleaned up the bar, before bolting in place. Note that the tow-hooks are almost directly in line with the lower cross-tube. This transfers tow/snatch forces mainly to the strong tube, placing almost no shear stress on the piss-ant factory mounting holes. We did, however, replace the upper bolts with slightly longer high-tensile ones anyway.
The finished product!
[/img][/i]
truck-fixer
Post by truck-fixer »
Nice job there mate. Will be building mine this week so is good to get some different ideas. Well done.
Smurf
Post by Smurf »
That bar looks a lot better on your Zuk than it looked on my Lux, good work.
have to test it out soon then...
suzuki_mike
Post by suzuki_mike »
Hey truck fixer, Have you got the pics of the bar you made yet?
truck-fixer
It's built and it's on. Just needs to be tidied up and capped to finish it off. Wasn't as simple as I had hoped so has been an episode of trial and error. :roll: Hope to finish this and have it painted by this weekend. Will post up when all done. :thumright:
truck-fixer
It's capped and finished. Getting it painted early this coming week so will be ready mid-week 8) . Will get pics posted up for you then while I have it off.
basics
Post by basics »
very cool 8)
truck-fixer
lneil
Post by lneil »
Hey truck-fixer, they are impressive bars. Is the rear just mounted to the rear chassis rails where a towbar normally goes?
truck-fixer
Yeh mate. They are mounted with crush tubes and HT bolts and the same goes for the tow hooks. Checked out a couple of escudos/vitaras down here from other clubs for ideas and they just mount theirs to the standard tow bar. So my beefy bar should be more than enough.
truck-fixer
Oh and thanks for the idea for mounting the front bars lneil. It worked a treat. :thumright:
Return to “Suzuki”
