series 70 transfer case ????
I'm looking around for a good 2nd hand transfer case for my 2LT & manual 89' LJ71 cruiser - mines friggn noisey . Will a transfer case off a prado with a 2LTe an Auto box bolt up to a manual box ( if i pulled it off the auto transmission & bolted it up the manual box ) or will this not work ???
Niblik >> strangely enough i did'nt get it , last i heard after you txted me , you were pickn it up last week ?
Kaney >> landcruiser Prado transfer case's are hard to come bye ( every now & then on trademe ) , i bought the wrong case awhile ago think'n a series 60 case 34mm idler will bolt up . then found out it does'nt (different input shaft or something ) , same with that terrain tamer kit t/case kit .
so back to square one now , well just found one , it has an auto attached to it, so wondering what i have to do to make it work ? what holes did you have to drill & what for ? I suspect my case is not too good as friggn noisey as hell down the freeway ( not 100% sure), reason why i just want to swap over .
