Transmission Problem
Guest
I have just bought a series 3 landrover, and in high range the 4x4 selector is in the depressed position, ie in 4 wheel drive. When i select low range it pops up, but i am unable to put it back into high range without depressing the selector. Any ideas why?
- mike
- Last minute Mike
So I take it you are stuck in 4wd then? If you cannot get back into high range without the selector down then this is high range 4wd in a land rover.
Try posting on one of these landrover forums. Don't think there are to many landrover experts on here at the moment.
NZ landrover email
http://autos.groups.yahoo.com/group/nz4wd/
or OZ Landrover forum
http://www.lrenthusiastforum.com/ubbthreads/postlist.php?Cat=&Board=UBB4
or World Series forum
http://www.lrenthusiastforum.com/ubbthreads/postlist.php?Cat=&Board=UBB6
Mike
NZ landrover email
Mike
When you select Low Range with the red lever it also automatically selects 4WD ie. you can't be in two wheel drive low range.
When in high the yellow is there for you to select 4WD - thats kinda stating the obvious....
To short a long story cut - your vehicle is [surprisingly] operating normally....
The three position Lucas switch - Dim, Flicker and Off.http://home.off-road.com/~bodgerover/
- mike
- Last minute Mike
Seems he got some answers on this post in the series forum
Forum Post
If that happens to mine I now know what to do. Buy a Zuk
Mike
Forum Post
Mike
