Under Bonnet insulation
dazza85
Post by dazza85 »
On the underside of the bonnet on my Isuzu (and the Surf) there is a layer of insulation which is molded so that it sits clear of the under under-side of the bonnet execpt at the edges and the central brace.
I have removed it to cut the hole for the inter-cooler scoop.
The question is why is it there ??
To keep the the engine cool ??
To keep it warm ??
To reduce the noise ??
Do I bother putting it back in ??
Jezza
Post by Jezza »
I took it off when I did my scoop, but then I put it back on as it was just taking up space in my shed, then it fell of while up the poulter after it had absorbed what felt like 10litres of water...... any way :D , It made no difference at all
Isuzu Mu 3.1TD
tallsam66
Post by tallsam66 »
Yep..its for sounds insultation.
Often they put similar stuff over the driveshaft tunnel of on the floor of the boot to redude transmission & road noise.
If it was designed to reduce or reflect heat it would have a silver alloy foil stuck to it to reflect heat.
Return to “Tool Shed”
