diff specs needed
Deiselboy,
I have had to try and source a speedo sender unit for my truck and have had no untold amounts of trouble, dicking around and straight bullshit. Out of desperation I rang Cockram Nissan in CHCH and spoke to the head mechanic and got the straight talk. He was really helpful, gave me more info then I needed even on stuff I wasn't enquiring about. Seemed he really wanted to help. Anyway, guts of the matter: give them a ring, can't hurt.
Albundy
Albundy
Yeah that was my next move.
I posted on OL.com and god(Bazzle) came to the rescue with in 10mins of posting.
New the spec's straight of the top of his head.
That guy is a walking patrol work shop manual.
The Patrol God.
Needless to say i am pretty stocked, saved me god knows how long pulling the diff apart and counting splines.The info in case its usefull to anyone else:
H233B LS Diff.
Axle Spline Count: 33 splines 33.3mm
Crown Wheel Diameter: 255mm
Crown Wheel to Carrier : 9 bolts
You never know, it may come in usefull to some one else!!!
Pete.
The Patrol God.
H233B LS Diff.
Pete.
Not sure at this stage Al, but i got this out of abit more pressuring!!
Front diff is H233B with 31 spline.
Rear is H233B with 33 spline, but has different locker part number for disk braked/drum braked models. H260 for leaf sprung cab/chassis.
Sooooo, if your rear LSD carrier fits my front diff, which i haven't looked into yet properly, chances are that your rear diff is a H233B with 31 splines on the axle shafts and an LSD.
I may be way off base here though. I'll see what i uncover as this LSD thing comes higher up on the list of projects in the near future
Pete.
Pete.
