landcruiser 13bt vacuum switching valve
- cornfarmer
Can anyone tell me where the vsv is on a 13bt. My engine will only run with the vacuum pipe off at the moment and is interesting to try to shut down.
- cornfarmer
- cornfarmer
Nah I haven't yet. Hopefully It wont be too expensive. I loaded the switch full of contact cleaner, it ran sweet until I hit a few bumps then stopped again.
Is your truck still running? If not pull the vacuum pipe off the big round valve by the throttle cable on top of the intake manifold. You will have to stall the engine to stop it, but will get you running again no probs.
- cornfarmer
- cornfarmer
