landcuiser hubs
kruzin
landcuiser hubs
Post by kruzin »
This is a long shot, but can anyone tell me the size of the nuts that are screwed onto the axle houseing inside the hub of a Bj 74 cruiser? I want to get a socket to fit this nut.
If its the freewheeling hub housing you want to take off they should be 12mm nuts
mike21
Post by mike21 »
has any one got any free wheeling hubs? they want to sell i have hilux/prado diffs i need atleast 1 thanx mike
mike21 wrote:has any one got any free wheeling hubs? they want to sell i have hilux/prado diffs i need atleast 1 thanx mike
I think I saw a couple of warn ones on TM for $40 today?
H2OLOVA
Post by H2OLOVA »
i take it your talking about the wheel bearing retainer type nuts? if so they're 54mm
niblik
Post by niblik »
http://www.trademe.co.nz/Trade-Me-Motor ... 086899.htm
ask the above vendor for a cruiser one... :wink: got mine through him.. :D
Do you have the manual hubs on at the moment? or are you converting these from those stupid toyota electric ones? if you are then its not a straight swop, you need an adaptor kit and then the manual hubs or what I just did to mine.
pradoman
hub spaner
Post by pradoman »
I have those spaners at work at a cost of $25.00.
Cheers Pradoman
PH 0800 310 088
oldblue
Post by oldblue »
If they are those "stupid electric ones" , then I can convert the over to manual for you, no need for the spacer ring kit.
Doh sorry forgot about your option...... :lol:
kruzin
Post by kruzin »
H2OLOVA wrote:i take it your talking about the wheel bearing retainer type nuts? if so they're 54mm
Yea that sounds about right. I just need a socket to undo them because im not a fan of useing punchs to undo nuts. Cheers mate!
red-devil
Post by red-devil »
if you had of asked early on this week i could have helped you out as i had a 54 scoket.
ill had it back around tue nex week if you need a hand stil
jono
kruzin
Post by kruzin »
red-devil wrote:if you had of asked early on this week i could have helped you out as i had a 54 scoket.
jono
Aw its alright mate, i just need to know the size because i have been offered a socket that will do the job from a mate who has a box of huge as sockets that never get used. Cheers anyway
