toyota diff pinion seal
Petemcc
Post by Petemcc »
The pinion seal in my rear diff of my surf is leaking a little. Can i just take off the nut that holds the drive shaft flange on and swap the seals over??
Pete
PR
In the crap again
Post by PR »
Yes :wink:
(021) 02388443
worzel
Post by worzel »
make sure you mark the nut before you take it off
because there is a collaspable washer in there and that determins the backlash on the diff so long as you tighten the nut back up to where it was originaly you will be fine
Make sure you get the right seal as there are two sizes got one from toyota 2 weeks ago it was about $8
Kev
Clint
Post by Clint »
worzel wrote:make sure you mark the nut before you take it off
Kev
Actually it's a collapsable collar & it doesn't determine the backlash on the diff, it determines the preload on the pinion bearings. Often a leaky pinion seal is the result of a loose pinion - grab the flange & give it a wiggle to check for play, reset the preload if required as well as replacing the seal.
Clint
UZJ71 Landcruiser
KTM 640
