pto drive shaft coupling
jumper
Post by jumper »
I need the coupling or yoke that connects the drive shaft to the winch head and to the pto output.
Has anyone got them :?:
1985 bj70 pto winch and three piece d-shaft
70 series?? pto
microwaved cheese on toast
jumper
Re: pto drive shaft coupling
Post by jumper »
bump
Kimbo
Post by Kimbo »
Hi There
Mine shit itself on Thompsons Track a month or so ago and after pricing one from Toyota ($660.00) I sent my remains to ADL engineering in Glenfield along with a new universal, and they did a great job trying to source one from NZ and Aussie but I was out of luck. They did end up getting me one which was slightly heavier duty and it fits great except for the hole for the shear pin which is larger(6mm). This meant I had to drill the hole in the winch input shaft out larger and as I use roll pins for shear pins I just got a 6mm x 50mm roll pin and I am back running again. I used it last saturday with no problems so are happy. Cost $235.00. I know it will probblary break somthing else before the shear pin but intend to double purchase when ever I can. Cheers Kimbo :D
