Anyone have any tips or lil secrets that could help? wood be much appreciated
siezed callipers
- mud_slinger
siezed callipers
i have a rear seized calliper on my mu so far i have covered the it in crc and also under the dust seal round the piston, i have a 6 inch g clamp pushin on it wit a old brake pad and it not budgin i even put a longer bar on it and ended up bendin the handle on it
needs more curry
0272593533
0272593533
nz4x4 wrote:I would pull the caliper off and replace the piston or give it a good clean. Only takes about an hour to fully rebuild a caliper.
but to do that he needs to get the piston moving....
try "inox". its a crc type stuff. works wonders. other than that you could maybe try a bit of heat? will stuff the seals tho.
Hi Mudslinger,
There is a trick with Isuzu rear disc's.
You need to back off the alan screw that adjusts the handbreak
Have a look about half way down ...
http://www.offroadexpress.co.nz/modules.php?name=Forums&file=viewtopic&t=8853
- nz4x4
WACKO wrote:nz4x4 wrote:I would pull the caliper off and replace the piston or give it a good clean. Only takes about an hour to fully rebuild a caliper.
but to do that he needs to get the piston moving....![]()
Pull the caliper off and blow compressed air into the brake fluid inlet, make sure ur get a good seal so pressure builds up, the piston will come out with a lot of force if its seized well so be careful. I reccomend a block of wood in front of the piston so it doesnt do any damage.
dazza85 wrote:Hi Mudslinger,
what he said.... dazz beat me to it
nz4x4 wrote:WACKO wrote:nz4x4 wrote:I would pull the caliper off and replace the piston or give it a good clean. Only takes about an hour to fully rebuild a caliper.
compressed air only works on one piston. youll still have trouble getting the others out.
- mud_slinger
