so a body lift was in order.
An ORE "Good Bastard" ELMO was conned into helping me do the deed this afternoon, sorry you missed the Waimak, not.
As it looked before work got too far on.
Who is that sad man?
Front end demolished.
Radiator cowling seperated from radiator.
Body block bolts removed from the drivers side and loosend on the passengers side.
This was the biggest jack I could find, no doubt there was a bigger one.
Half way there.
Houston, we have lift!
And just a wee bit of flex testing.......
Now I can get this sucker in the engine bay
The only things that caught us out were;
Both rear body block bolts wouldn't lign up, but the bottom of the body mounts here are supported with 4 studs on each one, that once loosend, allowed us to move the bolt around to lign it up.
The bottom radiator hose had to be shortend at the bottom end to prevent kinking.
Brake lines on the drivers side inner fender were binding on a breather hose bracket.
An AC line had to be placed under the rubber air cleaner piping to the turbo.
Slid the power steering hoses on both ends of the metal pipes, the smaller of the two may need lengthening.
Re aligned the top radiator hose.
Fuel filler and breather hoses were slid along the metal tubing and the plastic cover fitted back!
The radiator cowling fitted back in its origonal place, just a small 25mm wide rim that protuded on the bottom half of it had to be un-clipped and removed to allow the fan clearance.
Thre was bound to be something else, but my memory has gone numb!
There are still some mods to finish on it.
Find out why the front indicators won't go!
Raise the rear bumper,
Re attach the front bumper,
Lengthen the drive shaft U bracket,
Lengthen the handbrake cable hangers, they bind on full articulation,
Get winch mounted,
Get side bars manufactured,
And, finally, get it all certed.
This all started in a bit of a hurry as I failed my WOF this morning on my PC console up on the hood lining!
Her are 3 final shots of the truck;
1) Brand new, no mods,
2) suspension lift,
3)and with the body lift.
Why are all my pictures chopped short?, grrrrrrr!
