The start
Original bar and tyre mount off and ready to fit..... or is it?
New bar in place, BUT, note scallops cut out of flares!! For the bar to sit beneath the flares, i would only have been able to use four of the 8 bolt holes available, on the top row. The only way to mount it using all the securing points was to cut my flares. Not entirely happy, but had to be done.
Catch arrangement took some figuring. (No instructions came with the bar.) Thought I had it right, but the spare parts told a different story..... couldnt figure how it ALL was supposed to go together so went with what I had, and it works fine. Considering the latch mount needed 4 bolts and only came with three, im hoping the left overs were surplus to requirements anyway.
Affixed an LED rego plate light and zip tied the plate on, still not sure if this is going to be the final resting place, but I cant see any other suitable place for it. note the location of the Hi lift mount fitting brackets.... cant see how one can fit without taking off the tail-light..... anyone? anyone?
Tyre mounted and ready to rock. Decided to replace the suppled mounting bolts with our hi-tensile versions. Thiers were too small and with a single washer were pulling through the mounting holes when tightened. Used a beefier bolt and double washers. Had to drop fuel tank to fit the centre 4 bolts.
And the finished product. I've a tow ball tongue enroute to fill the reciever hole. Need now to make a mounting bracket to take the recovery hook to bolt to the chassis. This bar sits slightly lower that the original (but hugs the body line better, so no issue with angles) and obscures where the recovery hook was located originally. Had considered making another tongue for the reciever with a hook on it, as the Americans seem to do, but prefer to pull off the chassis, so thought better of that dalliance.
All in all im happy with the way it ended up, esp when it's half the price of the ARB rear bar and carrier. I have outlined my little problems with the supplier, who has passed on comments to the manufacturer. Not that i really mind too much, but im certain that others would have a major malfunction at, say, the thought of having to cut their flares.
whasmore, my darling wife is talking to me again now...... so yeah...... its all been worth it!!!
