130 series coil spacers
- muddyhilux
hi all,does anyone have a set of 50mm coil spacers for the rear end of a 130 series surf they might want to sell?or does anyone have a drawing they dont mind faxing/emailing to save me having to pull a spring and measure it all up,ill buy ya a box of ya favourite posion
Re: 130 series coil spacers
Would be less hassle to just buy some 50mm lift springs..coil spacers should be certified to be road legal.
Ive got the top spring pads that I pulled out of my Surf when I installed my coil spacers.
I can measure them up for you if you want. Will give you the diameter of the spring and diameter of the bump stop mount.
I also have Pics of my spacers before I installed them for reference if you want those.
chris
chris
LR110 ..... LJ50 project
- muddyhilux
yeh ive already got 50mm lifted springs but now ive got my spare 35 tyre in the boot along with my high lift jack and my tanks located where the original spare goes so arse is sitting slightly below front,and i normally carry a lil more gear so wana get it back up,plus havent gone for cert for all my other mods so this wont cost me any extra there and ill get what i want,yeh ubz the info and pics would be great,also are u stil interested in the 30mm steering spacer ive got?my project hity a 2month stand still so thats y ive been quiet but ive started back up again and remembered u were interested
here's the pic you asked for
40mm Coil Spacer on the left , original top pad and bottom pad on right
- muddyhilux
cheers for the pics chris and again for the pad,as long as i get material i should have these done by early next week so u should hear from me by mid week
