A-Frame and brakes
stinky
- House Hubby
A-Frame and brakes
Ok I have a small light weight Nissan which i Aframe around to save fuel the question is is it possable to hook up the brakes so i have in effect a braked trailer and if so can you explain how its done in terms a nissan owner can understand
turoa
- Pyro Junior
Re: A-Frame and brakes
no you cant uless you want to bleed your brakes everytime you take the a frame off
mudzilla
How do electric overide brakes work on a trailer ??
gazza
Surely if you fitted the same hydraulic system as is on the front of trailers now and it was left attached to the A-frame folded upwards while you are 4x4ing and was plumbed into existing brakes on towed vechicle, even if you had to fit couple of shut of valves to stop pressure going back to the master cylinder. you should have braking to the front
or am i missing summink
NO one remembers who comes 2nd....!
turoa
- Pyro Junior
its all good and well to have it all set up, you can do it, but when you want to take the a frame OFF its a major PITA (4wheeling with the a frame on is a PITA aswell). Its better just to buy/build a trailer. Im sure theres some tricky way to get it to all work, but its still an a frame
Ryan
i was on outerlimits a while back and over in aus they have to have brekes on vehicals being a-framed by law and there are a few camper van/bus companys who do it (electricly).... i suggest going on outerlimits and talk to the aussys??
Smurf
plumb in a trailer master cylinder, or similar with an external plunger, into the front bumper with a pin to disconnect the plunger from the A frame when you remove it. Slot the mounting holes on the A frame slightly where it attaches to the towed vehicle so the plunger can be activated by the weight of the towed vehicle coming forward slightly under braking/deceleration etc.
Works in theory like a trailer brake system, probably won't work in practice????
mercutio
could possibly do something by mounting another set of calipers on the front discs and having another braking circuit exclusively for the a frame
my 4wd is not a truck
- Yes Dear
you could buy a bigger Nissan or even better a Toyota to tow it with .....
sig
- Jeep Jeep
i know a guy who a frames his 40 around and what he did was hooked up a small electric compressor with a small tank in his forty,found an air ram plus solenoid .made a bracket so he could attach it between his drivers seat frame and brake peddle .to activate it he hooked the solenoid up to his brake light circuit on the tow vechicle so that when the brakes are applied it lets air into the air ram pushing the brake peddle down on his forty and when the brake is released the air ram unloads thus releasing the brakes .
Steve_t647
Not sure about price but I was looking for something I could make into a transfer case handbrake and saved this link
http://www.trojan.co.nz/index.asp?PageID=2145834357 I think it would have to be on a seperate caliper and closed system
Jezza
Steve_t647 wrote:Not sure about price but I was looking for something I could make into a transfer case handbrake and saved this link
The diff will just lock up one wheel if you use it while driving, could make it dangerous
Isuzu Mu 3.1TD
gazza
i,m Thinking about putting my fj40 on a-frame. Easiest way i can think to add braking is to use old style cable braking linked to the handbrake, would be simple to disconnect and rehook up
taz01
- Tazzles
my nissan is going on a frame .........but am towing it with a nissan too so shouldnt have any worries
WARNING:
abbo
taz01 wrote:my nissan is going on a frame .........but am towing it with a nissan too so shouldnt have any worries
NO worries at all because you wont see the 2nd one thru the smoke.......
Don't have 4wd.
- Yes Dear
from the cab or the exhaust ????
taz01
- Tazzles
abbo wrote:taz01 wrote:my nissan is going on a frame .........but am towing it with a nissan too so shouldnt have any worries
NO worries at all because you wont see the 2nd one thru the smoke.......![]()
sorry dude cant help myself
Jerry wrote:from the cab or the exhaust ????
awww shuddup
WARNING:
turoa
- Pyro Junior
taz01 wrote:abbo wrote:taz01 wrote:my nissan is going on a frame .........but am towing it with a nissan too so shouldnt have any worries
awww shuddup
is your nissan a bit ring a ding tony?
gazza
awww shuddup
Seeing that he has no wiper blades either...!!! does that mean he wont be able to see where he,s going or (with the smoke) wheres he,s been
stinky
- House Hubby
people as much as im enjoying your diggs at taz its not helping with the brake problem. Gazza how about a nice little pic of your idea
- Angry bird
Stinky, now that you've learnt to turn the choke off and it runs properly wouldnt it be much easier to slap a B Reg on it and just drive the thing instead of mucking around with A Frames and stuff?
stinky
- House Hubby
want to save my tyre wear and fuel but point noted. Hows this idea you bring that toy of yours in and we will extend the tray to fit my nissan that will save my fuel and tyres
- Angry bird
stinky wrote: Hows this idea you bring that toy of yours in and we will extend the tray to fit my nissan, build an internal roll cage for it, make up a full exo cage and do heaps of bar work and stuff, that will save my fuel and tyres
Yeah all options can be concidered
gazza
stinky wrote:people as much as im enjoying your diggs at taz its not helping with the brake problem. Gazza how about a nice little pic of your idea
Will draw something up ,also got my fj40 running today and have another regulator, so hopeing will get it out in the next couple of weeks. Might have a look at how i can do it on that and post pics ect
taz01
- Tazzles
why not build a car caddy ?
WARNING:
jumper
what about one of these
http://www.trademe.co.nz/Browse/Listing.aspx?id=172980728
microwaved cheese on toast
mercutio
jumper wrote:what about one of these
i can't see how that pivots would make it a bit difficult to tow with
gazza
mercutio wrote:jumper wrote:what about one of these
Built a few of these in uk. ok this is a basic one and i,m only replying to the comment that this dont pivot. If you a frame your truck you have no pivot (unless you hook it up to the steering) and to be honest this contraption is far more dangerous. It has hand winch to get it on and i expect they leave it attached so it dont fall off. But my main concern is the gaps for the wheels to fall into are way to small. The ones i have built have adjustments so the wheels fall down big time and then each wheel is ratchet strapped down. Looking at this one i would expect trouble under heavy braking. this would be ok towing a shitbox dirt track car down the road thats bout it
