Heya just fitted my 35" Creepy Crawlers i need some ideas on how to cut the corners of my front guards , i need to clear about 1cm each side, I have a angle grinder but thats about it, I would like it presentable as its a semi-tidy truck.
any iseas on what i need to do a tidyish job..
thanks 4 help
70 cruiser front guard chop.
- Sadam_Husain
- Angry bird
Re: 70 cruiser front guard chop.
crizpy wrote: i need to clear about 1cm each side
I explained to Curly the other day that sheilas talk in cm, sewing, cake tins and all that sort of shit.... blokes talk in mm
If its only 10mm..... um I mean 1cm you could probably tap it back with a hammer otherwise you'll be looking at cutting, welding, bogging and repainting
on one side ive Hit while offroading and damaged and that side is already pushed in and doesnt really need much more. But it also looks tidy enough.
so I guess your right I might take to it to a hammer atleast for now and if I want em done properly I guess i still can at a later time..
any tips on hammering them? block of wood on the corners? rubber head hammer? or use a rag or something
- Sadam_Husain
- Angry bird
crizpy wrote:any tips on hammering them? block of wood on the corners? rubber head hammer? or use a rag or something
When I massaged my firewall to fit the lefthand head I used a club hammer and a piece of carpet folded in two and that took most of the bruising out of the hammering
On your cruiser it should just be the back of the front gaurds that the wheels rub on, longer term you want to stick some 50mm body lift blocks under it and the tyres will clear the gaurds nicely
- skid
- Tyre Man
bring it to stokes valley on saturday and it will probably leave with some subtle massaging done
- niblik
- Sausage Shack
skid wrote:bring it to stokes valley on saturday and it will probably leave with some subtle massaging done![]()
you still talkin about his forby right?
