engine upgrade for ln61 surf
hijacd
Stropper
Post by hijacd »
i currently have a tired 2lt and what do you recomend for an upgrade?im thinking maybe a 28 diesel with a turbo?or maybe a 1kzte?any ideas?or maybe a petrol,something not to hard even though im a mechanic.
tnanx.
Steve_t647
Re: engine upgrade for ln61 surf
Post by Steve_t647 »
Not hard stick with what you have, 1kz is engine gearbox and computer new mounts and depending what gearbox there will be an offset rear driveshaft, 2.8 is the easier upgrade.
You could sort out the 2.4 better the devil you know especially if you are not a mechanic.
hijacd
Stropper
Post by hijacd »
i am a mechanic tho,do u recon i should wind up my boost and maybe fit a higher flowing exhaust untill it goes bang?then put in a 2.8 with a turbo.
SupraLux
Complete Bastard
Post by SupraLux »
What do you use it for? Do you want torque? reliability? fuel economy? There are hundreds of options, but you need to narrow them down by looking at what will work best for you.
hijacd
Stropper
Post by hijacd »
I mainly use it for day to day driving with the odd weekend trip in the bush,theres nothing really wrong with my engine i just want more power,along with reliability.i'v been told the old non turbo supra motor would fit straight in but will run a bit hot.i;v also been told the 2.8 diesel motor with a turbo would be the best option due to its power increase,ease of fitting and lack of cert needed.
andrew007
Post by andrew007 »
my truck started out 2.8,then 1kz,now lexus.my advice if i were in your position would be put a 5l in it.bolts straight in,then look at super charging with a/c clutch on super charger.pwr right off idle,no lag,& can turn off when not needed.ah cheap to run.should have taken my own advice. :oops:
gimmemud
Post by gimmemud »
Would be a hell of a lot easier to just sell the ln61 and get a kzn130. Price wouldn't be much difference and you get coils. Or sell the 61 buy a 60 with the solid front axle then do the motor swap. I personally wouldn't go to the trouble of engine conversion when you have the in between of the good models.
Just my 2c
hosehustler
Post by hosehustler »
andrew007 wrote:my truck started out 2.8,then 1kz,now lexus.my advice if i were in your position would be put a 5l in it.bolts straight in,then look at super charging with a/c clutch on super charger.pwr right off idle,no lag,& can turn off when not needed.ah cheap to run.should have taken my own advice. :oops:
Hi andy not hard to tell you've spent some time with Richard :lol:
But I gotta ask, why did you go from the intercooled 1kz to a lexus :shock: the 1kz would have CUT THE MUSTARD but most of all been RELIABLE especially on the drivetrain :shock:
I hate signatures
hosehustler
hijacd wrote:i currently have a tired 2lt and what do you recomend for an upgrade?im thinking maybe a 28 diesel with a turbo?or maybe a 1kzte?any ideas?or maybe a petrol,something not to hard even though im a mechanic.
tnanx.
Go an L series as it bolts in your mounts, 2.8 (3L) or 3.0(5L) turbo and intercool it, plenty of power for your needs, and easy to do.
I hate signatures
SupraLux
Complete Bastard
Post by SupraLux »
Yep, I'd go 3L or 5L... the turbo and plumbing from your existing setup can be retrofitted to the 3L to make it sing nicely while still being reliable and economical.
Steve
Steve_t647
If you do turbo the 2.8 you need to take the fuel compensator off the 2.4 fuel pump and put it on the new engines fuel pump.
You also want to make the exhaust manifold flow a little more free, stick with the L series and a turbo or supercharger for forced induction.
Oh and use an exhaust pyro to monitor the engine temps. :D
Return to “Toyota”
